Recommendation needed
40mpg
Dec 2021
Oakland, CA
82
Hello all,
I am looking for a recommendation for a device to monitor and record pressure. This is just an investigation, I feel that there must be a cheap solution to do this without needing a full blown PLC with HMI.
My client wants to install a pressure transducer (4-20) into a pipe and have a system records the reading every minute.
Have anyone worked on or deployed such a system? to record one data point without the need for a full PLC and HMI?
I was thinking products like this : https://www.sensorsone.com/33x-high-accuracy-digital-output-pressure-sensor/
I used a Raspberry Pi 3 along with dmroeder's pylogix to record data each time it changed on some vibratory welders but you still need a PLC... You could do it with LinuxCNC and an analog to digital converter. We have a torch height analog to digital converter that sends a pulse stream into LinuxCNC and using an encoder module to convert that to velocity then convert that to volts.
JT
I've read the threads for thermistors and hopefully get different results here w/o getting beat up too badly. No, I can not persuade the customer...
1,508
I need to use a 15" Panel Mount SVGA Monitor. Customer has specificed that it NOT be a touchscreen. My guy working on the project got a Rack...
2,908
Hello, Can anyone recommend an expandible IO module with OPC UA? I've deployed the Emerson RSTIO-OM module and it works great, but it has a...
67
I have worked on small projects using AB Micrologix but now we want to take a photo, process it online, and sort based on returned variables...
372
Just looking for recommendation on what others are using for switches. I'm working on a parts list for a project. I need 40 ports...
1,529
