rslogix 5000 instruction help
md.abdullah
Sep 2011
motihari
168
hello every one once again
i want a logic or instruction help which can find the solution of following....
there is an array TT017_testpoints,
this is two dimensional array in which at different point there is different value
also there is a uncorrected tag(which comes from field(real))
this uncorrected value will compare to this testponts in array
if it find exact of nearest value of the uncorrected tag in the array then i have to select that testpoint for the calibration
at that particular testpoint.
can any one proved me any help what type of instruction or logic do i use in rslogix 5000?
thanks rd
i used it but could not find any proper way
please can you show some sample way of this problem
please its urgent..
I surely can do your work for you, but if it is urgent I have to charge twice the normal fee of 100€ per hour plus taxes and expenses.
thanks rd
please its urgent..
Simply put, No.
As jvdcande stated above, I get PAID to "Show my work". You seem to have a bunch of "Urgent" requests, and want others to fulfill them. Maybe it's time you hired a contractor to tackle your project.
here is attached file
in tag list tt017_testpoints(two dimensional array[2,5])is array.
here is another tag tt017_uncorr(a real type tage) varies continously,so i have campare tt017_uncorr value to the array
if suppose it does strike in between to tt017_testpoints[0,0] and tt017_testpoints[0,1] then i have to move these points to AOI
such as
tt017_testpoints[0,0] = start_ point and
tt017_testpoints[0,1] = end_point
and coresponiding testpoints
tt017_testpoints[1,0] = min_error
tt017_testpoints[1,1]= max_err
to find the out
because it has for 30 trasmitter i have to make reusable AOI in rslogix 5000,any help dears.....yes tt017_uncorrect can vary in the range to the testpoints as it varry then i have to choose coresponding testpoints and these testpoints move to the AOI...
so i want this type of solution
downits looks some complex wayi read it carefully but did not implement itlook give me some idea about fgen componentam i rightor some brief eplain on the project you providedthank you dear
MD,
I would like to help you. My problem is that I do not have much knowledge about RSLogix5000. I know RSLogix500 well, but have not much expericence with RSLogix5000.
It appears that one problem might be your FSC Expression (TT017_uncorr < TT017_testpoints[control.POS]) & (TT017_uncorr > TT017_testpoints[control.POS]).
The above is the same as saying "IF X is LESS THAN Y, AND IF X is GREATER THAN Y, THEN (DO SOMETHING). You can see that the statement will be FALSE unless X = Y. I think you need a mathematical expression like this:
FSC Expression (TT017_uncorr < TT017_testpoints[control.POS+1]) & (TT017_uncorr > TT017_testpoints[control.POS])
Good luck with it.
Regards,
Lancie
Hey guys, thanks for taking the time to look into my question. I'm building a system to monitor several other systems for faults and one of the...
17
4,686
I"m trying to average an array of DINT's called FIFO_ARRAY. It has 1000 elements in it. Here is what I have entered into the AVE instruction...
4,792
Hello Please Help, I want to use a FSC instruction that will scan 20 DINT arrays. If the arrays are greater than 1000 display the value. How do I...
1,820
Hi There, When i did FRD instruction in SLC 500 its working, when i try to simulate in RSLogix 5000 same way as i did in SLC 500 which is not...
2,776
This is a real simple interface problem. Typically when I'm developing in ladder I will Ctrl+C an instruction and Ctrl+V, the new instruction will...
1,700
