RSLogix 5000 skipping version 19
OkiePC
Mar 2005
ENE of Nowhere Oklahoma
11,794
Today, I opened up my L23E QB1B Compaclogix with Embedded I/O, and it had a sticker on it that said version B, firmware version 19 or 20 only.
So, I opened RSLogix5k, and I have versions 16, 17, 18, and 20 installed. All our other controllers are version 16 at this plant, including the last in-motion checkweigher controller I built.
I decided to just use version 20 in this one. I had no issues with loading the firmware, although it somehow did time out and retry once about 2/3 through the process.
I am not expecting any surprises in performance, since the logic is so concise already.
I was wondering, though, will I run into issues with RSLogix5000 software having skipped support for version 19 in particular?
Would it have been a better choice?
No, I don't believe so, unless you try connecting to a machine with V19 installed (doesn't sound like that's likely). Otherwise make sure your v20 is v20.01 or newer, I had some weirdness with the Ethernet/IP driver that went away when I upgraded from the initial release.
It shouldn't be an issue to go straight to V20. I know some members have had issues with V20, especially with Motion control, but that was a Scan Time issue. I have only upgraded ours to V19, and I don't have any plans to go higher at the moment. In that case, I jumped from V15 to V19 directly, and had no issues.
Stu....
If you are not application "pushing" the CPU, "maxing out" the firmware should not be an issue; I've had to downgrade back to 19 a few L61s, however, they were pretty busy already with Vision and Motion components.
Rev.19 seems to be rock solid though; except for the extremely annoying RSL5K(substantial) hardware tree Online animation I have yet to find any flaws.
Hello, I am trying to read a barcode scanner input using a cognex dataman 280 barcode reader, store it another string, the compare with another...
60
Hi folks, in the alarm manager of Rslogix 5000, the tag-based alarm has been created. But when I tried to change the condition, it was found the...
168
I am completely stuck on building a ladder program that requires a start button to be pressed 3 times to turn on motor 1. Then motor 2 starts...
20
606
First off, I'm a hobbyist-level programmer, and this program isn't controlling anything anything that could even remotely be considered "life...
18
549
