RSVIEW 5 SE and VB
NumeG
Mar 2009
Parma
Hi to all. I have 2 questions:
1) rsview 5 se and visual basic:
I must create a excell file. In this file must be loaded 10 rsview local tags. How can i do?
2) i must call with rsview 5 se a html file. How can i do?
Try something like this
1) under Data Log Setup - you can log tags to an ODBC source. The in Control Panel/Administrative Tools, you should be able to set up excel file as an ODBC data source (provided you have excel installed)
2) command within RSVIEW like Appstart should work. You might be able to either call the html directly, or via "C:\Program Files\Internet Explorer\iexplore.exe" http://www.google.com
good luck,
tom
HI. i have created a excel file.
Now I want write in Cells(2, 2).Value = TAGNAME where TAGNAME is a Local Tag inside my project. I don't know how can write the instructions for TAGNAME. My PLC is 1769-L32E Compact Logix (RSLogix 5000).
Hello fellow wirenuts, I am looking to find the P.B. touch indicator option on version 13.00 and failing. It has been a year or so since I last...
329
Hello, I have converted RSView 32 to FTView SE 14 (I have tested FTView 12 before as well and there were some difficulties so I moved on to...
272
Okay, something I have not seen before.. RSView SE. I am working on an existing project. There is a value the customer wants trended and it is...
823
I have a request to integrate a pause button in RSlogix to be able to start/stop a video. Video format is not defined at the moment, so it could...
804
Hello everyone, I am having a problem with conversion from RSView32 to FT View SE Local project on version 12.00 (CPR 9 SR 12). Firstly, I have...
1,425
