frw312 Member F Join Date Jun 2005 Posts 85 Sep 10, 2009 #1 Is there a way to display jpg files in displays in Rsview. What I what to do is call them up from a touch animation? Thanks for any suggestions.
widelto Member Join Date Jul 2005 Location Barranquilla, Colombia Posts 3,392 Sep 10, 2009 #2 Rsview ME or SE On main menu: Objects, Drawing, Image then you can add your immage as .bmp or .jpg.
widelto Member Join Date Jul 2005 Location Barranquilla, Colombia Posts 3,392 Sep 10, 2009 #4 I guess so, you never mentioned what version you have. Last time I used rsview32 was more than 5 years ago.
Operaghost Member Join Date Apr 2002 Location Dallas, TX USA Posts 4,110 Sep 10, 2009 #5 Open a blank display or an existing display that you want to put the image in. Go to File => Open Click on the Files of type dropdown. From the list of file types select JPEG Files. Select your image. The image will open in a separate window, so drag the image into the desired display (that you opened in step #1 above) OG
Gil47 Member Join Date Apr 2007 Location South Island, NewZealand Posts 1,319 Sep 10, 2009 #6 One more thing get the image to the pixel size you want before taking it to RSView, as once you bring into RSView trying to scale its size will make it look poorer quality or in some cases garbage.
frw312 Member OP F Join Date Jun 2005 Posts 85 Sep 10, 2009 #7 Thanks OG that works great, very much appreciated !!
