RSview SE and SLC5/05
huynt
Nov 2004
106
Dear all.
In my system, we use two SLC5/05 and two controllogix PLC. They connect to use Ethernet/IP protocol and hirchmann switch with ring topology. We use RSviewSE connect with RSlinx. Use RSSQL for transact data. But have ploblem some day ago, some data from SLC5/05 can not display. Data in RSSQL is OK. I use Data monitor of RSlinx view data, data have error. You can help me about that.
Thanks.
huynt said:
Dear all.
Thanks.
It's probably a problem with your ring topology setup.
I could be wrong here, but I don't think Hirschmann switches are capable of mannaging a ring topology network.
What model from Hirschmann are you using?
I would start by converting it back to a simple star topology.
Thanks.
I try with star topology, but it isn't OK. Data from Controllogix alway display OK. We use Mice II switch, they are redundant managed switch. You think problem from SLC5/05 or from RSlinx?.
Thanks.
I'm going to show my networking weakness. I have an installation in which we have five production lines and one common feed system. All of these...
2,446
Hello fellow wirenuts, I am looking to find the P.B. touch indicator option on version 13.00 and failing. It has been a year or so since I last...
331
Hello, I have converted RSView 32 to FTView SE 14 (I have tested FTView 12 before as well and there were some difficulties so I moved on to...
275
Okay, something I have not seen before.. RSView SE. I am working on an existing project. There is a value the customer wants trended and it is...
825
I have a request to integrate a pause button in RSlogix to be able to start/stop a video. Video format is not defined at the moment, so it could...
806
