RSview Stand Alone
Daniel Lopez
Feb 2007
Diamond Bar
I have created an application using rsview studio, I created this application using the stand alone option because we are using one PC to communicate to a SLC. My question is how do you make your opening screen open up in a maximize mode when loading the Stand Alone Client? I choose the option to open maximized, but it still opens in a small screen and it requires you to click on the maximize button.
Your help is appreciated,
Daniel Lopez
I use RSView32, and what I do is create a shortcut on the opening operator screen.
In the shortcut, I have the 'Target' to the RSView32 Runtime program, "RSViewRT32"
"C:\Program Files\Rockwell Software\RSView\RSViewRT32.exe"
This must be in quotes, and with a space following it.
Then, following the space, the path to your project *.RSV file, for example...
"C:\Program Files\Rockwell Software\RSView\Projects\Project.rsv"
That must also be in quotes, then another space after the quotes,
Then after the space ad a /r
So your shortcut 'Target' should end up looking like this..
"C:\Program Files\Rockwell Software\RSView\RSViewRT32.exe" "C:\Program Files\Rockwell Software\RSView\Projects\Project.rsv" /r
Also select the Run "maximized" in the dropdown.
This will open RSView Runtime, then Open your project and run it.
I do that on all operator stations, set them to auto-login on power-up, and put that icon in the center of the screen, so if they have a problem, the can pretty much power up and get going on their own.
RSView SE StandAlone is really just a bundled SE Local-only mode server, and a standard client.
The client configuration screen (just run the client application, not the shortcut) should enable you to maximize the display, show/hide the titlebar, show/hide the diagnostics list, etc.
Hello fellow wirenuts, I am looking to find the P.B. touch indicator option on version 13.00 and failing. It has been a year or so since I last...
329
Hello, I have converted RSView 32 to FTView SE 14 (I have tested FTView 12 before as well and there were some difficulties so I moved on to...
272
Okay, something I have not seen before.. RSView SE. I am working on an existing project. There is a value the customer wants trended and it is...
823
I have a request to integrate a pause button in RSlogix to be able to start/stop a video. Video format is not defined at the moment, so it could...
804
Hello everyone, I am having a problem with conversion from RSView32 to FT View SE Local project on version 12.00 (CPR 9 SR 12). Firstly, I have...
1,425
