Running Proficy Machine Edition and Plant Edition on the same PC
BrianSS
Mar 2011
Findlay, OH
Hello,
I am attempting to run a Machine Edition HMI app and a Plant Edition HMI app on a single PC, and I am not able to get them to run at the same time.
What happens is if I have the Machine Edition HMI screen up, I can start the Plant Edition app, which appears to start correctly, as it shows up in the taskbar. However, if you try to click on it, it will not show up, almost as if the application is locked up. Closing down Machine Edition fixes the problem
Anyone seen this or know where my issue may be?
I have ran ME and PE on the same machine many times, but not ME View which is the ME HMI app. Not sure if that's possible as the drivers may conflict with each other.
I would contact GE-IP support and run this by them.
I have no experience with Eaton HMIs. I downloaded the Galileo software and I am trying to get the file on a HMI (XV-102-H3-70twrl-10) to modify a...
145
How to fix if appears code “$115 plc-restart running” on the screen OP17
252
Here's what happened, Operator turned on the disconnect for an auger while it was still running to cut power. Auger DID in fact turn off, but the...
352
Hi! I am trying to run the 'SimpleSample' (https://infosys.beckhoff.com/content/1033/TF5100_TC3_NC_I/Resources/3438746891/.zip ) to understand the...
109
A new point I/O rack is to be hooked up with the running PLC. In point I/O, it is supposed to be the OA4 card to be installed as per the...
99
