S5 program help
srik
Sep 2005
hyderabad
104
I know the PLC program in Ladder/Functional block only. However I seen the S5 program in statement list. How can I able to understand the statement list? and also Iam new to Siemens PLCS..
The program as follows.Can any one help me to understand the logic?
Advanced thanks.
Segment 1
:C -DB39
:L DD 30
: KG +4000000+3
::G
:C -DB6
:T DD 24
:C -DB6
:L DD 234
:L KG +1000000+3
:XG
:C -DB39
:T DD 33
:C -DB6
:L DD 236
: KG +100000+3
:XG
:C -DB39
:T DD 72
:C -DB6
:AN D 233.0
:C -DB39
:= D 40.8
:C -DB7
:L DD 70
:C -DB39
:T DD 79
:C -DB39 //call DB39
:L DD 30 //load data double word 30
: KG +4000000+3 //'L KG' load constant value (K=Konstante) real (G=gleitpunkt) +4.0+3 = 4.0*10 to the power of 3 = 4.0*1000
::G //divide real-numbers
:C -DB6 //call DB6
:T DD 24 //transfert to data double word 24
:C -DB6
:L DD 234
:L KG +1000000+3
:XG //XG ? multiply real-numbers
:C -DB39
:T DD 33
:C -DB6
:L DD 236
: KG +100000+3
:XG
:C -DB39
:T DD 72
:C -DB6
:AN D 233.0 //and not
:C -DB39
:= D 40.8 //if D233.0 is true then D40.8 is true
:C -DB7
:L DD 70
:C -DB39
:T DD 79
:L KG +4000000+3 //'L KG' load constant value (K=Konstante) real (G=gleitpunkt) +0.4+3 = 0.4*10 to the power of 3 = 0.4*1000 = 400.0!!!
:C -DB6 //call DB6
:T DD 24 //transfert to data double word 24 of DB6
:C -DB6
:L DD 234 //Load data double word 234 of DB6
:L KG +1000000+3 //Load +0.1E+3 = 100.0
:XG //XG ? multiply real-numbers <- OK
:C -DB39
:T DD 33 //Store the result (DB6.DD234 * 100.0) in data double word 33 of DB39
:C -DB6
:L DD 236 //Load data double word 236 of DB6
:L KG +100000+3
:XG //Multiply by 100.0
:C -DB39
:T DD 72 //STore in data double word of DB39
:C -DB6
:AN D 233.0 //and not data bit 233.0 of DB6
:C -DB39
:= D 40.8 //if D233.0 in DB6 is false then D40.8 in DB39 is true
:C -DB7
:L DD 70
:C -DB39
:T DD 79 // Copy data double word 70 of DB7 to data double word 79 in DB39
Real numbers are entered in a special way in S5: only the mantissa is entered and the exponent. The number is then interpreted as being of the form: 0.mantissa * 10exponent, e.g. KG +1234567+3 is to be read as +0.1234567*10+3 or 0.1234567 * 1000 = 123.4567.
Kind regards,
Please find the following link
for programing manual
www.fer.hr/_download/repository/S7_300_STL_programming_manual.pdf
I have an old Sentry Palletizer (S/O Number 3007 / Serial Number 1172) that has lost its program as the backup battery died years ago. I can...
56
Hi all, hope you are having a great day, I am in need of your help to create a AOI or program that does this kind of job: I have a IO Link...
26
549
190
I am completely stuck on building a ladder program that requires a start button to be pressed 3 times to turn on motor 1. Then motor 2 starts...
20
605
Hi all, I’m new to programming and want to write a simple routine. Push start button, turns on sensor. 2 second delay before anymore logic read...
341
