S7-300 connection with Smar Fieldbus
Iman
Jul 2010
Tehran
172
Hey guys,
I've a pilot plant that are controlled with Smar instruments with Fieldbus standard. I'm going to control the plant by S7-300 (PID control)and use the Smar instruments. In another word, I just want to implement the PID control in S7 and read and write the new value into the Smar. I have the OPC server in my station and connect all the devise through Industrial Ethernet to a Hub switch. But at this stage I don't know what should I do exactly to read the tag by S7 from Smar or OPC server and how to write the new value from S7 to Smar or OPC server. Do you recommend any idea or a good manual for this job? By the way I communicate station to S7 and station to Smar through industrial ethernet perfectly.
Thanks in advance.
Sounds like you have a lot of coding and trial to do.
Unless I had a lot of spare time; with an S7300 I'd go for a standard fieldbus like profinet or profibus.
Kalle
Edit: You should check with Smar if they've already made functon blocks for S7 interfacing!
Is it possible to give me a tip or guide line how S7 can read the defined tags in OPC server? I mean, how S7 communicates with OPC server(any vendor).
We are changing the plan and we want to setup a direct connection between S7 and Smar fieldbus.Do you know any guideline for this connection? Both devices are conected through TCP/IP.
Folks, I have a client with an old ABB Advant / MOD300 system (v14.4). Around y2k I installed the ABB Industrial IT MOD300 OPC Server 1.1/2...
202
When E300 powered off, the ethernet device tag data stayed at last know state, for example, fault bit is still Off, ready bit is still ON, status...
1,041
Hi Experts Thank you very much for your support and help. I am completely new to MODBUS, I have S7300 where CP341 is installed to send and...
1,712
Hello Every one I am trying to connect the encoder with siemen's 300 plc but dont know how to do it... Could some one send me the connection of...
2,225
Hi, I have a PC with WinCC 7.4 and a PLC 315-2DP with 343-1 card. I cannot get connection to the PLC in the tag management while settings of the...
2,109
