Safety FLT S03 Powerflex 527
helphelphelp
Feb 2020
Canada
41
Hello,
Currently trying to replace a powerflex 527 drive in a machine for motor rotation. The drive is wired the same way and it is the exact same revision number but the drive comes up with a S03 fault when it powers on. I can see the drive status and the IP address is set.
Any idea why this might happen?
Any help is appreciated,
After some interesting conversation regarding the safety of emergency stops, I saw some posts talking about the safety standard conversation...
26
888
Hi, I am using AB 5069-L306ERS2 CPU. My system should achieve SIL-2. I have safety door switches connected to AB 5069-IB8S module, and I want to...
123
I'm struggling to get an FR-E800SCE to work on CC-Link IE TSN. I'm sure the issue is with the drive, when I plug in the network cable I get no...
115
Hi I have a yaskawa gp7 robot arm which I am going to use for machine tending with a cnc mill. Is it a good idea to buy a SICK laser scanner for...
256
Power flex 527 Network based safety drive had faulty and alarm pop up SOS Code internal fault Unable to set or clear the fault manually or...
136
