Safety I/O
JeffKiper
Jun 2006
Indiana
2,462
Guys what safety I/O are you using? I have been using 1768-L43S, 1768-ENBT, and I have only used 1734 AENT with both safety and statndard Point and it looks like a good standard setup so far. Just looking for other things that I might have missed in the AB arsenal. I am trying to stay away from DNET
I ASSuME that you can't use anyone else's Safety Ethernet I/O with AB processors because of the safety CIP packet. I haven't seen anyone do this yet but it never hurts to ask.
If it is a small count then I use the safety point IO or if there is other vanillia point IO that I need in the area or if there is a ton of safety stuff I use the guard IO blocks.
After some interesting conversation regarding the safety of emergency stops, I saw some posts talking about the safety standard conversation...
26
888
Hi, I am using AB 5069-L306ERS2 CPU. My system should achieve SIL-2. I have safety door switches connected to AB 5069-IB8S module, and I want to...
125
I'm struggling to get an FR-E800SCE to work on CC-Link IE TSN. I'm sure the issue is with the drive, when I plug in the network cable I get no...
115
Hi I have a yaskawa gp7 robot arm which I am going to use for machine tending with a cnc mill. Is it a good idea to buy a SICK laser scanner for...
256
Power flex 527 Network based safety drive had faulty and alarm pop up SOS Code internal fault Unable to set or clear the fault manually or...
137
