Servomotor heating by gearbox
aand74
Dec 2005
Deinze
131
We have some Siemens servomotors that are overheating.
If we look at the load, current and speed, there is no reason at all for overheating. Also the installation has been running ok for 3 years and the
the thermal conditions have not changed, also there have been no adaptations to the installation.
I did some temperature measurement with infrared thermometer and saw that for all motors, the gearbox is hotter then the motor surface.
So my opinion is that maybe the gearbox gets hotter and heats up the motor too much.
Does anybody have similar experiences?
Are there any lubrication requirements for this gearbox according to the manual? Over lubrication or incorrect lubricant is as bad as no lubrication sometimes!
How are you picking up that there is an over temp condition in the first place? Was a protective device being tripped?
a gearbox should be handable (your hand flat on box should be possible.
a motor should be touchable meaning a fingerfor 1 second.
check oilquality and obvious level as the upper gear should be oiled.
check bearings, and gears, by vibration measurement.
and yes i do this .
Kindly, has anyone tried to control Lenze servomotors with Siemens S120 drives ? Any special hints ? Have some concerns for the resolver and servo...
238
hi goodday to all, i have acopos 1320 as below title my acopos not driven a servo motor,. please help me,.
447
Can we open a servomotor body, then reassemble it again without issues ? Because the customs at the airport want to see the inside of the motor ...
863
Do you know a supplier for the following item? Similar parts and other brands are acceptable. cooling fan for servomotor mounting Rexroth...
1,365
Kindly, we are using ip65 servomotors on diaper and tissue machines. But we are considering the ip64 servomotors for new projects. Has anyone...
1,015
