chapani
Firejo,
So ON ENI side is set RS232 baud rate on Auto, Ethernet on auto, and just is set IP address and subnet mask.
SLC DF1 (channel 0) settings are
driver : DF1 full duplex
Parity None
Stop bits 0
No handshaking
Error detection CRC
Embedded responses Enabled
Duplicate packet detect enabled
Source ID 9
Baud rate I tried to vary from 19200 to 1200 step by step but from RS Linx ethernet devices driver I can see only ENI card and DF1 port, Normally it should detect SLC5/04 on ENI IP address but it doesn't.
thank you
Parity None
Stop bits 0
No handshaking
Error detection CRC
Source ID 9
thank you
