SLC 5/05 ethernet comm
tmdphillips
Oct 2005
Toledo
I am trying to configure my RSLinx via Ethernet/IP devices setting and am looking for 133.133.120.40 and RSLinx does not "see" it. I am an experienced user who has never had this problem. Any suggestions? Any way to "ping" this IP to see if it is set up?
Well, yes, just ping it. Command prompt ping will work.
Is the SLC-500 and EthernetIP device? Or is it just plain old AB Ethernet? If it is regular ethernet, you need to use the ethernet driver, not the EthIP driver. You will also need to configure the driver with the IP's of the 'Expected' stations.
Are the subnets set up right?
Also try going online to the 5/05 via serial and check that:
1. The IP address is still set to 133.133.120.40 (no typos)
2. That the BOOTP box is deselected.
3. Check that your cabling is OK. (I've wasted so much time running ethernet problems down, trying everything and finally swaping cables which has fixed the problem, even with new, just-out-of-the-bag CAT5)
Since you are an experienced user I'll skip the usual "what is your IP address ?" routine and give you two of my hints.
First, the SLC-5/05 has only recently come to support the EtherNet/IP browse response. Controllers that are more than two years old will probably not have the firmware that allows them to be "seen" by the RSLinx EtherNet/IP browsing driver. They will still be accessible, as are all PLC-5E controllers, via the Station/IP correlation list in the regular Ethernet Devices driver.
Second, the EtherNet/IP browse can be blocked by several common firewall and VPN products. The Windows XP SP2 firewall, the default settings of ZoneAlarm, and CheckPoint VPN software have all been the culprits on various installations that I have seen.
I want to be able to use a 3rd party device to read the IO modules from an SLC505 without the use of the CPU. All the communications modules i...
32
15,269
Hello, I am setting up a SLC-500 rack and cannot get my Ethernet communication to work. I have set the processor to default. Set up my serial...
3,061
Got a quick question on ethernet communication. I have an SLC 5/05 who is talking via ethernet to a panel view and two other machines. The IP...
1,898
We have a SLC 5/04 running and would like to communicate with it over Ethernet rather than run DH+ cable to it as there is a PLC5E unit close by...
3,587
Has anyone used one of these? http://www.prosoft-technology.com/content/view/full/2497 We have several SLC's (mostly 5/04's) in the plant that...
5,485
