SLC 501 Transmit Enable
DanYost
Oct 2005
Lancaster PA
397
I am not sure is transmit enable is the proper term, but that is what we call it. Pin 5 (or 3 depending on how you look at it) of a SLC503's DH485 port outputs a square wave that our G3/DSP/MC use to determine whether or not we can transmit. A customer of mine sent me his SLC501 which he was not able to get to communicate with a G3. I have it set up in my office, and I am seeing the same thing. If I connect a PIC to the same network, then we start talking.
My question is, is there a way to enable the transmit enable pin in the 501?
Thank you,
Dan
Any body have an idea?
I would like to avoid telling my customer that he may need to shell out any more money.
Thank you,
Dan
I've never heard of a way to do that. But, have you tried just jumping that pin to one thats always on on the G3 side of the cable? I'm pretty sure the 5/03 doesn't actually need the hardware handhsaking. I'll admit most of my experience has been with RS232, so i could be mistaken on that point. But it seems worth a try. Jump RTS and CTS on your other device, so that as soon as it requests permission to xmit, permission is granted.
-jeff
Thank you for the response. I wish it was as simple as that. I have tried pulling the line low and high, but to no avail. To the best of my knowledge it actually needs to see the transition of the line in order to operate.
Regards,
Dan
Does the other piece of equipment have an RTS type of line that turns on and off that you can tie it back to?
I've actually never even used a 5/01, but I figure if I keep throwing suggestions at ya, it'll keep bumping the thread up until someone smarter than us comes along, right?
Anwyay, back to the original question. As far as i can tell, the pinouts are the same for 5/01 and 5/03 DH485 ports. I've been looking in my software, and i can't find anyplace to set it for hardware handshaking, or full duplex or modem operation. Not if I have a 5/01 processor or if I have a 5/03. If there is a way to enable/disable the CTS line, that would be it.
-jeff
Hello I will make it short and sweet. I need the cable that goes from the slc 501 to the 1747-UIC RJ-45 connection. From what I can find it...
1,269
Greetings All, Just wanted to share a little adventure I has last evening. A facility that we are leasing calls and has a problem with a piece of...
1,817
I'm going nuts trying to figure this one out. I have a processor that faults every time the power is cycled. The thing is, when it faults it...
18
7,284
I'm having problem connecting to the 501 plc with 1747-uic adaptor windows xp sp3 recognises the adaptor but rslinx cannot locate the plc. I tried...
20
5,158
Two of my power module for SLC 501 have failed myteriously. Both of them were functional a year ago when those systems were build. While starting...
4,357
