Telemecanique Instruction set
Jezz
Dec 2002
Kendal
399
Hi All
We have an old Telemecanique TSX-47 PLC and are currently looking into converting it to AB, as that is now our site standard. The problem is we only have a printed copy of the ladder and no one is familiar with the instruction set.
Does anyone know what the following mean/are
+----COMPAR----+
-|C1,V >= 150 |-
R+---C1----+E
P| |D
U| C,P: 0 |F
--| MODIF: Y|--
D| |
+------OPERATE-------+
|W46 + 1 -> W46 |
R+---D6----+F
| TB:100ms|
U| |
--| LEN: 6 |
|4 -> D6,s |
Hi Jezz
1. Compare Block
This will act as 'NO contact' and be a logic 1 when counter 1 (C1)actual vaue is greater than 150
2. Counter
Up/down counter:
R= reset
P= load preset
U= count up (rising edge)
D= count down (rising edge)
E= empty (underflow)
D= done (preset reached)
F= full (overflow)
3. Operate Block
In this case is incrementing internal register W46. (W46 +1 then transfer value back into W46). Should have one shot contact somewhere in control line or it'll do it every scan.
4. Drum Controller
R= reset to step 0
U= advance a step (rising edge)
F= full (on last step defined)
TB= time base
LEN= no of steps defined
5. Operate block
This is forcing drum controller D6 to step 4
Regards
Kevin H
www.krkautomation.com
I have an old PLC (circa 2007) consisting of Telemecanique/Modicon/Schneider Electric devices. The system has developed errors and unfortunately...
254
Hello! Sorry for the unusual question not quite on the topic of the forum. We have a computer museum. We got an old PLC programmer telemecanique...
1,632
Good Afternoon , I'm not too familiar with the Telemecanique Compact Smart Relay SR2B201BD . Is the software free , and would any of you...
1,575
hello I am facing a problem! we have a TSX17 old telemecanique PLC on a machine the machine was off for a several years so the PLC battery has...
3,452
Hello All I have a project for upgrade a Telemecanique XBTG6330 HMI I, can not Find the right software for it and programming cable any Idea...
1,049
