Tension Control in Compact Logix
BTunnicliff
Mar 2014
Long Beach
Hello All,
I am fairly new to programming ladder logic in general and I am looking for a little nudge in the right direction. To give a quick background I have an ME background and just started writing PLC programming for this new company so I have experience with only writing code for one small slitter/rewinder (Thin plastic sheeting).
To give a quick rundown of the project I am working on. The system I am currently working on is a 1769-L33ER AB compact logix controller. I am using the most current version of Studio 5000. The system I am working with is a turret winder that is running thin plastic sheeting, .5 -5 mil. This has a top and bottom turret that will be running at the same time.
My responsibilities: The main speed of the machine will be determined upstream of my program from the main nip drive. I will be able to see this speed but I will not be controlling it. So the rewind portion of this machine has a dancer roller for trimming speed to the rewind shaft. This is supposed to help maintain my tension for my material.
My Questions: On my first slitter/rewinder that I programmed I only controlled the tension with the pressure of the dancer roller, and all the speed matching was done outside of the PLC. (Explained to me buy our electrical guru here: Main nip speed voltage is trimmed by the dancer position which then gives the rewind spindle speed that it should be running. As the roll grows the spindle must slow down to maintain constant line speed.)
So now I want to be able to do this all in the PLC because there are times that I need to give the rewind spindle a different signal than the dancer position. I.E. During turret cutover the empty spindle must be run at line speed which will be different from an empty core, 3.5" OD, to a full roll of 24" OD.
I have looked a lot on this forum for tension control theory and learned a lot, but I am just getting stuck on how to write the actual logic. If anybody has any sample code they don't mind sharing with me it might be able to help me over this hump.
I know this is very long winded, but if anybody can help it would be much appreciated. Please if I am not clear on my description of the system ask me for clarification.
-Brian
I was either going to use the speed of the main nip and the RPM of the rewind spindle to calculate the diameter with math. OR I will be using the the layon roller positioning to know the diameter of the growing roll. I have concerns with both so I am not sure which is best practice. I tried to pitch the ultrasonic sensor to my boss but they did not go for it.
Here is a common block diagram- I don't work with AB products so I cant help with the code- I'm sure others will chime in
You will definitely need some decent filter blocks
The position controller in post 4 is really a PI controller. Just use a +-10% trim
The diameter calculation does most of the control
Maybe this will give you some ideas
Good luck
I spoke with somebody who wrote code for an existing winder and it sounded like that's why they use the layon roller position for the diameter rather then calculating it. But then sometimes we run film with the layon roller out of the way and we won't know anything about the diameter.
Does anybody having any specific code setup with PID loops for tension control?
I would suggest you post what you have done so far for people in here to help and give many suggestions. If you are looking for someone to send their whole winding tension control program I don't think you are going to get the response you are looking for.
Thanks for the advice. Unfortunately I am running out of time and I think this is a little too far over my head for a second project. I am going to let my electrical guy wire up the drives and tension outside of the PLC like he normally does. I will then use a relay to control the signal to switch from the dancer signal controlling the rewind spindle that has material on it, to the PLC telling the empty spindle to run at line speed during the cutover process. This will then switch back to dancer control after the cutover.
Anybody see any major issue with the concept?
www ab com/linked/drives/drvappsw/files/AppModl_Center_Winder/9329-RM002B-EN-E.pdf
literature rockwellautomation com/idc/groups/literature/documents/rm/9329-rm003_-en-e.pdf
You should look into your power flex, it has it's own trim PID for a winder application, real simple to set up. Parameters 130-139. They explain it in the manual "apppendix F".
I recently started some machine addons to a wrapper line. We have the process working well for the addons. We were looking at already programmed...
2,533
Hi Dears, Why we can not use beam type load cell for web tension control? Which is use in weigher. Best regards,
3,233
Consider a textile machine with a first roll pulling material from a supply box. After this first roll there is a dancer roll, that the first roll...
7,082
Hy sirs, we have the following special application: A web is passing through a dancer which is mounted on two linear bearings. One unwind motor is...
21
11,223
i am doing a project in which i have unwind a paper roll , for this i have contol the tension using brakes , i just have following information ...
2,534
