Unable to make 1756-RIO module's RIO LED steady green
Jun 2014
Perth
Hi All
I'm working in a project using a 1756-RIO module as RIO scanner to communicate with a 1771-ASB adapter mounted in a PLC5 rack also with a Panelview 1250 plus. Everything works very good in terms of data transfer but I can’t get the "RIO" LED in the scanner steady green. It stays green for around 5s d then turns red for 1s and so on.
According to the manual this light turning red means:
"A frame-receive error has been received in the last
second (CRC error, abort, or time-out). Indicator stays
red for 1 second after the error occurs.
One or more racks are in error."
However, the diagnostic tool in the module indicates no errors in the communication with any of the two slaves. (Refer to the attachment) so I’m very confuse.
Note:I don't have the recommeded cable yet (Belden 9463) so I'm using Belden 9441 with the recommended resistor of 150 ohms in the two network ends. Could it be the reason?
I would really much appreciate any help you can give me in this case. My customer doesn’t like that red flashing at all.
Thank you
I am running CCW 13 trying to upload to a micro 820 vers.12 I get an output message OPC server is unable to load project controller. Please help!
286
I've posted this on the ptc forum as well, but no luck with an answer (waiting for my service contract number) I keep getting the following error...
154
I have just installed Studio 5000 V30.11 on my Windows 11 Pro machine. First I had an "Invalid Pointer" error that required me to update Factory...
141
Hi, One of my customers has an old fabric tensile testing machine. The IC # AD7501KN of its controller has malfunctioned. This IC is related to...
91
Hi all, I'm having difficulties trying to connect FactoryTalk View SE Local Station (V13.00) to MS SQL Server Express. I state that they are...
158
