What is level 3 automation ?
Does this help?
Purdue Model for Control Hierarchy (5-Level Model)
Level 0 Sensor Level (Measuring Devices):
Pressure, Temperature, Speed, Accelerometer, Force, Position, Shape, Thickness, ...
Level 1 Controller Level (Feed-back Closed Loop Control):
Speed Regulator, Tension Regulator, Sequence Control, Position Control, Temperature Control, SCADA
Level 2 Machine Level (Set-up Models):
Temperature model (e.g., EAF, LMF), Shape Control, Mill Set-Up Control, Coil Tracking, Runout Table Cooling Control, ..
Level 3 Operation Unit Level:
Blast Furnace, Electric Arc Furnace, LMF, Caster, Reheating, Hot Mill, Cold Mill, Anneal Line, Pickle Line, ...
Level 4 Plant Level MES, MRP:
Scheduling, Material Flow, Manufacturing Execution System (MES)...
Level 5 Corporate Level CRM, TMS, ERP:
Order Process, Enterprise Resource Planning (ERP)...
Hello everyone Iam working on washing machine which washing onion and water level is very critical for the process. The machine used IFM 121 for...
122
Hi I have a ifix 5.5 application where the operator opens a valve by clicking on a screen object. I can trace from object to data base that it is...
49
I want to measure the tank level and get the sensor output to the PLC. Below are the details : Tank Height =0 - 3m, the sensor is stalled 0,2m...
706
Does anyone have RSLogix 5000 ladder diagram program of tank leveling (factory IO). Fill valve, discharge valve, set point, level, etc? I looked...
169
