Wonderware and an AB Micro 850
JaxGTO
Apr 2009
Kalieefornia
1,072
Anybody have any success using a Wonderware Intouch 11.1 and a Micro 850? According to WW they don't have a Micro 850 driver and I have to use the Micro 850 Modbus mapping and the WW Modbus driver :mad:. Yea that's not ugly. Besides the Micro 850 will only map 200 tags to Modbus. With recipe management I need at least 450 tags.
I am thinking now just using a Kepware driver or just talk the customer into a PanelView Plus.
Any thoughts?....Jack.
I agree with either Kepware or Topserver as an interface. They have a driver for almost anything and their support is outstanding. I have made it a rule in our organisation to use topserver between our PLCs and SCADA. You cant go wrong for the little it costs.
They are exactly the same when you look at the software packages and their drivers are exactly the same. Not sure who the actual developers are, but i know Kepware and Softwaretoolbox are product partners. Like i said it is exactly the same package just under a different name.
The AdvancedHMI Micro800 driver uses native tag addressing and works simply by using the ControlLogix driver and completely removing the route path since there is no backplane to route through. Does the WW ControlLogix driver allow you to remove the route path?
No such luck, but great idea. WW driver is very ridged in it's configuration and requires a BackPlane device.
My customer decided to go with the Topserver driver.
Thanks all.
Hi guys, I have experience with PLC to Excel etc...just starting on using intouch scada screens. I have an Excel sheet that uses mainly...
158
Hello everyone, Recently, my Archestra IDE shut down while I was editing. After restarting the IDE, I noticed warning symbols under my opened...
104
Good morning all. I'm working on a rehab where they had a standalone InTouch 2014 HMI that they called a SCADA, but it's really basic stuff. The...
187
Hi, We are setting up an Aveva Plant SCADA node with the intention to connect it to a Wonderware Historian node. Everywhere I look online I see...
184
Hola chicos. Tengo un problema con el driver de comucicacion dasabcip 5, y un plc controllogix v34, ya realice la comunicacion pero en ciertos...
167
