Wonderware Woodhead Siemens comms
odonnea2
Oct 2006
Dublin
17
I have a Siemens S7 CPU412-2 with an CP443-1 ethernet card. On a PC we have installed Wonderware SCADA software with a Woodhead Direct Link PLC Communication driver. The Woodhead I/O driver uses a parallel port license key (A sentinel driver is used to tie the Woodhead software license to this hardware dongle).
My problem is that I have been getting intermittent communication problems between the PLC and SCADA. The whole system has been up and running with the current configuration but after a recent reboot of the PC we have lost comms (and cannot see any live data on the SCADA graphic).
The Communications on the PLC ethernet card look fine
LEDS TXD and RXD are flashing green.
The link on Port 2 of the card (where the ethernet cable is installed) is solid green and the RX/TX LED is flashing.
Similarily the comms on the PC ethernet card are good and the ethernet connection is enabled and running.
No dirver settings have changed.
I have tried rebooting the PC and cycling power to the PLC but have had no luck.
Does anybody have any experience with this type of setup?
Thanks in advance
Thanks...
As it turns out this was an issue with the PC name. The original vendor PC had been replaced with a standard company PC. The original vendor PC had the name SCADA, while the new PC was named something else. The AccessName in Intouch is configured with the node name SCADA, and it was unable to resolve this name to the local PC IP address. When I added the IP address and the name SCADA to the Windows host file, communnication was re-established between Wonderware and the I/O Server.
I am still not too sure why communications were okay before I had the aforementioned comms problem however.
Hi guys, I have experience with PLC to Excel etc...just starting on using intouch scada screens. I have an Excel sheet that uses mainly...
153
Hello everyone, Recently, my Archestra IDE shut down while I was editing. After restarting the IDE, I noticed warning symbols under my opened...
102
Good morning all. I'm working on a rehab where they had a standalone InTouch 2014 HMI that they called a SCADA, but it's really basic stuff. The...
183
Hi, We are setting up an Aveva Plant SCADA node with the intention to connect it to a Wonderware Historian node. Everywhere I look online I see...
180
Hola chicos. Tengo un problema con el driver de comucicacion dasabcip 5, y un plc controllogix v34, ya realice la comunicacion pero en ciertos...
165
