Wonderware
RY_Guthrie
Nov 2011
Las vegas, NV
263
I am running Wonderware 10.1 on a Windows XP machine which is a working application. We have the same Wonderware application running on a Windows 7 machine through a private network. The problem is the Windows 7 machine will not display data coming from the running XP machine currently in use.
I could be mistaken but, if the same WW application is running on 2 different
machines, -they both recieve duplicate data from the plc simultaneously. Why
would the Windows 7 machine recieve (display) data from the XP machine? It should be
displaying exactly the same data via each machines own I/O server? I don't
know about Windows 7, but I have run 2 exact WW applications on 2 different
XP machines, neither application sends or recieves data from the other machine.
Neither running application depends on another running application to display
or recieve data, if the WW apps. are the same. ?? Does the Windos 7 machine have
ANY live data?
wonder ware
We are using one machine as the "server" to gather data from the plc's and the other machine is acting as a slave and getting its data thru that machine. We are doing this with another xp machine and it works great, just having trouble getting the 7 machine to work. We have decided to use virtual box and run xp and try that, from what we have been able to learn it is difficult to make xp and 7 running ww to share data.
I migrated to a WSP2023 application. Now when I open a HMI object (for example a valve or motor) the popup is first correctly show as defined ...
31
204
Hello everyone, Recently, my Archestra IDE shut down while I was editing. After restarting the IDE, I noticed warning symbols under my opened...
129
Good morning all. I'm working on a rehab where they had a standalone InTouch 2014 HMI that they called a SCADA, but it's really basic stuff. The...
218
Hi, We are setting up an Aveva Plant SCADA node with the intention to connect it to a Wonderware Historian node. Everywhere I look online I see...
214
