RTD signal over power cable
cornbread
Feb 2007
madison, indiana
407
A bit off topic, but I have an old heat trace controller where they used the power cable to get the rtd reading. They have lil pc board at the rtd the converts the signal so it can be carried on the 120vac ckt back to the panel. Naturally they are no longer in business and we are looking at replacing the panel. I hate to run new RTD wires for a standard control. Does any know if some one make a converter to impose a rtd reading over the 120 vac ckt? Guess I could wireless, but I hate to go down that path if not needed.
Bartec maybe?
Wouldn't a power line communication device do? You'd still have to get the RTD into an Ethernet packet, but those are fairly standard still.
I used to use these guys a lot years ago, partly because when I had my integration business, they had chosen the same name and had to come to me with an acceptable alteration of it. But their LCM (Line Carrier Modem) products worked great, I used them at Boeing for communications on overhead crane power rails even though they went through brushes.
http://data-linc.com/a-quick-look-at-the-lcm100-ac-power-line-carrier-modem/
Hi guys, im looking for a way to monitor 20 RTD probe into 2-3 PC. I hear that there is a way to convert RTD into Ethernet IP and read them with...
1,607
Good Morning , I have a RTD , that I would like to wire into a 1756-IF8 Analog Input Card. Would you all a simple wiring diagram , of what...
1,251
Good Afternoon , It seems like we always have problems with using Type J Thermocouples with our slip rings . Would using a RTD at 10...
1,680
We are running a power flex 70 connected to a Delta V and I cannot get the drive to start because I am getting a STOP ASSERTD message on my HMI. I...
3,190
I am working on an installation that will require sensor cabling interconnecting sensors to PLC subject to outdoor temperatures. Will the ambient...
2,078
