What the Main difference between PLC and DCS
naeemmsc
Nov 2008
kARACHI
33
I want to know what is the main difference between PLC and DCS.if PLC Perform every task why we use DCS.Plesae can some one tell me about DCS5000 literature web sites.
A PLC system CAN work by itself. However, if it relies on, or supplies signals to other components to operate, then it MAY be called a DCS. It's the idea of "distribution"; many components, or many components working together? The term of "DCS" is pretty vague, to be honest.
In manufacturing you make either 'things' or 'stuff'. Traditionally, PLCs have been mostly involved in the manufacture of things and DCS have been mostly involved in the maufacture of stuff.
The dividing line between the two gets less distinct with each new generation of controllers.
PLC means programmable logic circuit
in general it means a sophistacted relay box that can be programmed with a ladder program. So simple on/off in a line and some timers/counters.
DCS means digital control system Almost same , however programming is done in basic, C, pascal. The in and outputs are not standard
Historically DCS developed in the process industries and were the result of adding capabilities and communications to single loop PID controllers and using mini-computers for HMI functions. Many DCS systems use proprietary communications protocols and have proprietary programming languages, although most modern systems are more open and flexible.
PLCs grew out of component and product manufacuring as relay replacement systems. Most program in Ladder Logic but modern units have a wede variety of programming languages, analog I/O capabilities, math functins, and communications.
You have hit upon a discussion that has been raging in the industry for 20-30 years. Over the years, the two have come together to the point that there is not a whole lot of difference. The biggest difference is probably in their origins.
PLC's originated with discrete control. Designed to replace large amounts of relays. This also is the reason for PLC's dominant programming language being ladder logic. The target audience was electrical engineers and electricians. Ladder logic is well suited to the core training of both disciplines so EE's and electricians can understand ladder programs due to their similarity to electrical ladder diagrams. Over the years the functionality required by advanced ladder programs has somewhat negated this advantage. Many of the commands available are in no way comparable to electrical components. PLC's have also expanded to include structured text programming, function block programming and step programming. Analog I/O and capabilities have been developed to cover a full spectrum of possibilities. SCADA systems have developed to be paired with PLC's to allow full visualization and data manipulation.
DCS's originated to fill in with analog control. Developed for process industries, they were designed around process engineers - usually chemical engineers. They were designed for large systems and generally were programmed with some form of high level language or function block programming. They now have ladder and discrete functionality and even tend to look more like the PLC's. DCS's tend to integrate the visualization and data manipulation better than their PLC counterparts as their configuration is usually a single system designed to work as a whole; however, the PLC manufacturers have made strides into duplicating this capability. The costs of DCS systems are generally higher than comparable PLC systems.
I really dont see a lot of difference today between the two platforms. EE's tend to gravitate toward the PLC's still and Chem E's tend to still gravitate towards the DCS's. The PLC manufacturers are constantly trying to break the image of small system and/or discrete machine control even after all these years. Many of them have gone to calling their upper end controllers PAC's or programmable automation controllers. Change the name lose the stigma.
A more focused question is to ask What are the Main differences between PLC's and DCS controllers?
By which I mean let's not look at the networking, HMI etc, but just at the controllers themselves.
And here there are still differences that go back to the Discrete origins of PLC's and the continuous origins of DCS's
With a PLC you can code close to the metal, easily setting and responding to individual bits, bytes or words, or even tables of them with confidence that the program will use little memory and execute fast.
This is not the case with the controllers in most DCS's.
The best definition I ever heard was that if the salesman tries to sell you a chair its a DCS.
My view is that the historical definitions are no longer valid. A Control Logix processor has never been a PLC in the original sense and the PC based modern DCS's are a million miles away from a Rosemount System 3. Selection needs to be based on engineering criteria rather than outdated terminology.
Andybr
Thanks for all those response my question.But one thing is still not cleared that if any task can perform PLC so why we use coslty DCS system Is there any limitations Of PLC that we have to use DCS>Thanks
hello sir welcome to the automation world. What is the main difference between 1747-SN and 1747-BSN modules in AB.If any one knows pleaae...
1,937
361
Hello Everyone- I'm working on a new network deployment of AssetCentre and I am not able to authenticate with the application using our...
418
TLDR: I try to establish the OPC communication between Kepware OPC DA Client to ABB 800xA OPC DA Server. In the Kepware OPC quick client of poll...
876
Main rack contained power supply 140cps52400 and 140cpu43412A and RIO HEAD 140CRP93100 in addition to another I/o cards . Another remote rack...
1,902
