What the Main difference between PLC and DCS
I have/do work with both. The biggest differences in my opinion are.
1. DCS systems do fault tolerance and redundancy much better. The PLC's are not close...yet.
2. It is much easier to do complex controls with a DCS, yes you can do the same thing with a PLC, but it takes a lot more code.
3. Only one tag database in most DCS systems. With a PLC/SCADA system, each has there own list of "tags".
4. PLC/PAC controllers are much faster, but hold less. Most DCS systems have 100msec scans or slower.
In short, PLC/SCADA systems may require more engineering effort, at least that is what the DCS people will tell you. Certainly this is true for continuous processes and those with relatively little discrete control. Also DCS's tend to be more easy to configure for things like redundancy.
PLC is a programmable Logic controller which is used mainly for interlocking different equipments.
DCS is Distributed Control Systems which is used to control very big plants by using simple GUI screens.PLCs are interfaced with DCS for interlocking.
SCADA is Supervisory Control and Data Aquisition which is used to control and Monitor small number of Equipments in a field.SCADA systems are typically used to perform data collection and control at the supervisory level. Some systems are called SCADA despite only performing data acquisition and not control.The supervisory control system is a system that is placed on top of a real-time control system to control a process that is external to the SCADA system (i.e. a computer, by itself, is not a SCADA system even though it controls its own power consumption and cooling). This implies that the system is not critical to control the process in real time, as there is a separate or integrated real-time automated control system that can respond quickly enough to compensate for process changes within the time constants of the process. The process can be industrial, infrastructure or facility based as described below:
Difference between PLC and DCS
hello sir welcome to the automation world. What is the main difference between 1747-SN and 1747-BSN modules in AB.If any one knows pleaae...
1,930
176
Hello Everyone- I'm working on a new network deployment of AssetCentre and I am not able to authenticate with the application using our...
403
TLDR: I try to establish the OPC communication between Kepware OPC DA Client to ABB 800xA OPC DA Server. In the Kepware OPC quick client of poll...
852
Main rack contained power supply 140cps52400 and 140cpu43412A and RIO HEAD 140CRP93100 in addition to another I/o cards . Another remote rack...
1,864
