SLC 50/3 Connecting to Local Network
jatkinson924
Jan 2018
Nashville, TN
Does anyone have an suggestions on connecting a few SLC 5/03s to a local network? I've got a few Ethernet switches mounted in our ceiling for other PLCs we are using and would like to make the connections there.
The Rockwell way is to use a 1761-NET-ENI that connects the 5/03 serial port to the network. You can find them on Ebay for S250 - $400, but make sure they have an Ethernet port, as some listings for NET-DNI's call them NET-ENI's but are DH+ not Ethernet
I am sure there are other aftermarket devices others on the forum will know of.
You could do a network but I think I would do Paul's suggestion with the Digi. If you had a 485 network inplace then I would look at just bridging the network to a Ethernet network
Are the RS232 (DB9) open on the 5/03?
No the HMI is connected thru the RS232 port. Would I need a Digi for each PLC? or daisy chain a DH485 network and have the Digi at the last PLC? The PLCs are around 60 ft of each other?
You have a few options but none are great.... do you have a budget? you may want to think about changing them to 5/05's
Well at least their not asking a lot :)
I still think it maybe cheaper to buy some used 5/05's and changing out the CPU's
Are the 1500's a LSP or LRP processors
So on the 1500's you can change them for 1400's or use a 1761-NET-ENI or padees Prosoft (not sure of cost either) or OkiePC's Digi (525.00)
The LSP only has one port but your LRP has two so you can add the device to your unused port
What some ways to connect an Ethernet only PanelView Plus to a SLC 5/04 without upgrading it to a SLC 5/05?
16
4,994
Hi there, I am doing a site survey for an older plant which my company has started working with. There are mutliple different PLC's around the...
4,454
I have a SLC504 in the field that is communicating DH+ to several other SLC504 and the RS232 port is communicating to a panel view plus 1000. I...
1,272
Hello, I'm a electrician who is furthering my education and learning to be a programer , I have a Dell laptop running windows 7 with rs logics pro...
22
6,292
Hello everyone, I have a question about connecting to an S500 PLC. I have been tasked with going to site and taking a backup of a program from an...
3,867
