Modified sine curve motion
aand74
Dec 2005
Deinze
131
I already succeeded in programming a function to find parameters of fifth order polynomial, in the runtime of a motion controller.
To use if at runtime the cam has to be calculated.
Next to polynomials there also exist sine curves for cam profiles.
More in specific, when should I use the modified sine curve?
When does it have an advantage to a polynomial?
I suppose a modified sine curve is a sine curve where the first and last part are not a pure sine, but the middle part is.
If I should write a function to be executed at runtime in the controller, to calculate a modified sine curve, based on start and end position and velocity,
how should I start? What function should be used in the first and last part?
For the sine part, how to calculate amplitude, phase and period?
When you say sine curve do you mean s-curve?
s-curves start and end a ramp with the acceleration at 0.
This can be done with half a sine wave but it is not clear what you are trying to do.
A sine is generated using a polynomial. Usually the order is very high.
A fifth order polynomial will execute faster than a sine function. The motion profiles are similar. The peak acceleration using a sine function is 1.57 or PI/2 times the average acceleration. The peak acceleration using a 5th order polynomial is 1.5 times the average acceleration. You can see there isn't much difference.
I do not know what you mean by modified sine curve.
To do what you want to do requires calculus. The motion controller should have these functions built into firmware. You should not need to write them.
Hi, The hardware is: Click Plc model # CO-O1DD1-O HMI model # S3ML-R magnetic-inductive flow meter model # FMM100-1001. I will set the flow meter...
211
Looking for some assistance. I am very familiar with Yaskawa VFDs, but not so much with AB VFDs. I am working on some hardwired AB PowerFlex 700...
163
Hi, I'm working on a project (AB PLC, L85 v34) where we'll have 20 motors installed, all controlled by powerflex 750 series drives. We need...
979
On my laptop I have an old.acd file with important comments in it. The file was modified and downloaded to my AB-1756 long time ago. Later a few...
2,034
Hi, I'm currently working on a machine equipped with Rockwell PowerFlex VFDs. I have one PowerFlex 753 (rev 6 or so) and two small PowerFlex 4M...
2,016
