Low Cost Ethernet I/P VFD
Greg Dake
Jun 2005
Milwaukee, Wi
550
Greetings,
I am looking for some ideas on low cost VFD's which natively support Ethernet I/P. Looking for 3 phase, 480V, 2h.p. and less. Just need them for conveyor motors, no elaborate control.
TIA,
Greg
Personally I'd avoid Schneider drives like the plague. I did a project earlier this year with the Altivar ATV320 controlled by an S7-1500 plc over Profinet and it was a nightmare. Such a rigmarole to just get them to run and their tech support people in the UK and in France still haven't been able to tell me a method that works for clearing a drive fault using the reset command in the control word. Another nicety I found is that if you use STO on them and they go into a SAFF safety fault the only method I have found to clear this is by doing a complete factory reset.
Hi Folks,
Thanks for the abundance of response! My standard is the PF525, however I am trying to find something less expensive.
Greg
I was in the same boat.
I looked at several drives: Siemens, Schnieder, lenze, other Allen-Bradley (pf 40/etc) and they all seem to run pretty close together in costs by the time you figure the drive + communications card.
They are close enough to be a wash.
IMO, just pick a drive based on controls. Use PF525 for Rockwell, G120 for Siemens, etc.
I'd sure be interested to see some real numbers from an OEM / Integrator. AB prices are all over the map, depending on who the customer is.
Hi guys, May I ask if you know of any device with as few as 3 inputs and capable of ethernet connectivity? I have a project to monitor a number...
20
6,853
I'm a beginner in the automation field and I've set up an automation system connecting several devices (datalogger, radio, etc.) via Modbus RS485...
215
Hi folks, We have been working on our own controller after many decades of using the "big names". What would your ideal motion-controller be...
48
8,384
I was wondering if any one had an idea how I could implement an amperage reading to the plc. I have two PWM valves which draw about 3 amps...
1,628
Hi everyone I'm in the process of automating my home brewery. To get control of levels i was thinking of measuring the flow of water into the...
9,000
