Low Cost Method to Read Amperage On a PLC/HMI?
WireGuy1950
Jun 2005
Fairport Harbor, Ohio
155
I was wondering if any one had an idea how I could implement an amperage reading to the plc.
I have two PWM valves which draw about 3 amps maximum. Currently (pun), I use two 0-3 Amp meters in-line with each valve. I would like to just read the current into the plc analog input directly and display on the HMI.
I have extra analog voltage inputs available so I was thinking of a small shunt or resistor installed in a terminal block.
This is on a production machine, so it has to look professional and be repeatable. The PLC is a AD P2K.
DC or AC?
Try searching this forum with terms like "measure current with plc"
The range goes from clamp-on devices with 4-20mA outputto power monitoring devices that speak Modbus (e.g. here).
I'm a beginner in the automation field and I've set up an automation system connecting several devices (datalogger, radio, etc.) via Modbus RS485...
215
Hi folks, We have been working on our own controller after many decades of using the "big names". What would your ideal motion-controller be...
48
8,392
Hi guys, May I ask if you know of any device with as few as 3 inputs and capable of ethernet connectivity? I have a project to monitor a number...
20
6,863
Greetings, I am looking for some ideas on low cost VFD's which natively support Ethernet I/P. Looking for 3 phase, 480V, 2h.p. and less. Just...
32
10,631
Hi everyone I'm in the process of automating my home brewery. To get control of levels i was thinking of measuring the flow of water into the...
9,000
