Low Cost Ethernet I/P VFD
...or the Mitsubishi E700 series, both of which are likely to be cheaper and support Ethernet I/P.
I'll second the Mitsubishi recommendation, I used to work for a distributor that sold Mitsubishi and new customers can get some prime pricing here in the States.
I did a project a while ago at an old company. Loads of vfd suppliers, loads of options.
So I did things like "STO for this sized drive would save me this much, so if the drive has STO, it gets an £x bonus over a drive without."
"Ethernet /IP" was worth something as well.
"Dimensions" was harder to quantify, but I did a "volume discount" column which always gave me a chuckle.
Ethernet/IP was always £100 or so over a similar drive without. I didn't need it. Plus all the infrastructure like switches and IP tables and security.
For me, under 7.5kW Eaton DE11 came out on top. CANopen built in. RJ45 connector daisychaining everything, just need a CANopen gateway. No STO, but our risk assessment was that you couldn't access moving parts without killing power via upstream safety contactors to the whole machine.
Nice form factor too @45mm/90mm wide depending on kw.
We made custom RJ45 daisy chains, the ones EATON sell are.. not as neat.
Hi guys, May I ask if you know of any device with as few as 3 inputs and capable of ethernet connectivity? I have a project to monitor a number...
20
6,882
I'm a beginner in the automation field and I've set up an automation system connecting several devices (datalogger, radio, etc.) via Modbus RS485...
216
Hi folks, We have been working on our own controller after many decades of using the "big names". What would your ideal motion-controller be...
48
8,398
I was wondering if any one had an idea how I could implement an amperage reading to the plc. I have two PWM valves which draw about 3 amps...
1,631
Hi everyone I'm in the process of automating my home brewery. To get control of levels i was thinking of measuring the flow of water into the...
9,005
