Transfer Project from GE 90-70 to PAC System (Rx7i)
jawad rasool
Feb 2012
Lahore
51
Dear all,
good day
I'm looking for some help in transferring a project from GE 90-30 to GE PAC System (Rx7i), if someone had already done it or know about any manual containing information about the procedure, please let me know....
My major concerns are;
Will I've to modify the PLC Logic?
Will the Addressing be changed in this procedure??
There is a manual available here, but it does not specifically cover 90-30 to Rx7i.
The manual number is GFK-2722. If you do not have an account, you can create one to be able to download this manual.
I have not converted a 90-30 to an Rx7i, but I have to an Rx3i.
The addresses did not change, but there can be problems with the nickname of the variable.
There are some instructions that are different, so some of the logic may have to be modified.
There are also newer instructions available that may make you WANT to change the logic. I was able to eliminate some rungs after a conversion because of the newer instructions.
When you convert, a report is generated and shown in the info viewer. Any problems will be listed.
Just FYI, the Rx3i 12-slot backplane fits into the same mounting holes as the 90-30 10-slot backplane.
Also, you can use some 90-30 I/O modules with an Rx3i.
You may consider changing your Rx7i to an Rx3i and make your conversion even smoother.
Can I use this procedure to transfer 90-70 project as well???
We converted the WinCC project. But it was difficult. A lot of scripts were running in the background. The only problem at the moment is...
553
Hey guys, our s7-300 broke down yesterday and i wanted to take the same project from it and transfer it to another s7-300. But i do not know how...
4,677
1,357
Hi everyone I'm having trouble transfering a projec from my PC(wincc Flex 2008 sp2 Win7) to an HMI simatic panel(tp177b pn/dp 6"cstn). I 've...
3,561
Hi, guys, how’s going? There is a Factorytalk View Studio project “AAA” in my old computer. We want to transfer it to the laptop, then we can...
2,746
