Big thanks to you, this is clear now what is the difference between the single station and distributed server.
Just for curiosity, what would be the advantage of running SE single station VS Machine edition?
Just behing able to host the application on the server?
When we say "Server", it does not literally have to be a Windows Server machine. It can be Windows 10/11. The software uses the name "server" to indicate that it is serving the data up to its clients. But commonly, you do see it running on a server, especially the distributed applications. A local application I wouldn't hesitate to use Windows 10/11.
With Local applications everything runs on one PC. The client and the server are the same computer. The server cannot send data to any other client. With Network Distributed, everything can be separate machines if we want to do that. For example, one PC can be the HMI Server. That PC stores all the graphic displays. Another PC can be the Data Server. That is the computer that makes the network connection to all the PLCs on our system. And we can have multiple other computers that are clients. The client views a screen and it gets that screen from the HMI Server. The data that is displayed on that screen comes from the Data server. By distributing these functions, we put less of a load on those computers.
You can certainly have the HMI Server and the Data Server on the same PC with the clients being remote computers. In fact, that is how most applications I have seen are set up. One server box and a bunch of remote clients.
SE has a lot more capability than ME. It has better alarming functions, data logging is a huge improvement. The ability to act on events (such as: if this happens do that), Trending is better. Macros are better. They really shouldn't even call them macros in ME. VBA is there if we want to use it. Graphically there isn't a huge difference since it is the same editor. But you have a few more animation capabilities. Simple things like pressing one button that can open two displays, launch Excel, and set a tag to a specific value. There is also a whole command language in SE that you have access to that you can't access in ME.
And yes, running it on a PC versus a dedicated terminal is helpful too. Although you can actually do that with ME applications too.
There are a lot of great software packages that are as good as, or (much) better than SE. SE gets pummeled on here pretty regularly, often fairly so. But compared to ME, it is a big improvement. I've used both for years and I definitely prefer SE over ME.
Usually it comes down to who are we creating displays for. If I am creating displays for the operator running a piece of equipment then ME is usually the tool. If I am creating displays for users in a control room that need to see current production data along with what we did yesterday or last month, then that is likely SE. Assuming Rockwell is their preference.
OG
