marlonhiram12
Hello, everyone.
I'm trying to communicate with an SLC500 Processor through a PLX51-DF1-ENI Prosoft Module. This module is a DF1 to Ethernet/IP converter.
To get the data I'm using Ignition 7.7 with an OPC-UA Connection. I had no luck doing this and I'm starting to get frustrated...
It is assumed that the module works like the 1761-NET-ENI module from AB.
I don't know if someone of you guys has done something like this successfully. I did a lot of research on the Internet and I can't find anything about this topic. The only thing that I found is that there are other two DF1 to Ethernet modules that work properly.
One is DIGI ONE IAP and the other is one from MOXA.
