AlfredoQuintero
Hello to Mitsubishi experts.
I will probably be tasked with configuring the Mitsubishi Electric "MELSOFT MX Sheet (SW2DNC-SHEETSET-J)" utility for a processed food manufacturer who uses Melsec-Q. This utility runs on Windows 10 system and using the Mitsubishi Electric communication component (MX Component) over Ethernet, which permits access to the processors' registers, and trough some simple configuration it is possible to log data on MS Excel worksheets.
The idea is not to have to change anything on the PLC program nor the HMI, as this will add engineering costs from the machine vendor which not a local company. I need to register the time at which the triggers get activated, and the simple way is to use the Windows 10 system time. But if possible, I would like to get the time from the Melsec Q processor. So here is my question: Does the Melsec Q store the sytstem time on some system variable that can be accessed externally through a Melsec client such as MX Component, to get the time to the Windows system? Thanks.
