Vijeo Designer Fonts
janner_10
Dec 2014
Tewkesbury
1,301
Has anyone managed to get windows fonts into anything other than text only fields?
The built in ones are bloody awful looking.
I dont think its possible. But the text objects can be used for everything except when you are using message displays with text resources
Yes you can
Extract from help file
11.3.2.1 Working with Value Animation
From the Graphical Objects toolbar, select the Text icon.
Click and drag to define the text area, and the Text Editor will open.
In the Text Editor, type the pound symbol [#], which will act as the numeric display, then click OK.
Use only one pound symbol [#] character to enable Value animation—no additional text, character spaces, or carriage returns. The pound symbol must be a single-byte character.
In the Text Property Inspector, define the color and font as needed.
Right-click the text object and select Animation to display the Animation Properties dialog box.
Click the Value tab, and select the Enable Value Animation checkbox.
Define a variable or expression.
Click OK to confirm the selection and close the Animation Properties dialog box.
Good Day all. I am currently busy with a schneider HMI design in vijeo designer and i want to know how you can animate an image to move on the x...
180
Hello, I have been tasked with adding some analog signals for display and alarm setup in some old Schneider Electric HMIGTO HMI-panels. I have...
179
Since upgrading to V6.2 12.24 SP12 24-21 the M221 PLC is no longer recognised by the HMI. The screen still works but it does not talk with the...
998
I work for an OEM. I am trying to develop a generic HMI program that will display an overview screen displaying between 2 and 6 "widgets"...
1,311
Hey all, I am using Vijeo Designer v6.2.8.12 for a mineral plant project. For that, I needed to incorporate three different plants' HMI page in...
1,202
