comm of pc and plc
jyotidixit
Guest
J
hi,
i want to do pc and plc communication through rs232.
pls give all the required info.
thnx,
b4n
Go to communication setup in programming software and then select the port and the device which u r using and then click connect thats all . But before that u have to do hardware configuration of the device which u r using . thats all plc will communicate with the pc .What ever u want , either download the program or upload u can do .
please write the whole question as which plc do u have what is the configration of ur pc.Then I think u will some good suggestion as I had seen here with out that neither u get the information what u like to get nor the information provider able to give.
thank u
jyotidixit,
this is a bouncer! If you want from us all the information for the solution, why don't you give us all the information regarding the problem? Or are you, as I suspect, indeed one of those lazy zzzzz students we're all fed up with?
If you want an answer, show us you've put some effort in it. At least state the right and complete questions!
Hi; In a cabinet of a machine, a Fatek PLC with an Ethernet communication card is working. In the same cabinet, there is a 1 kW inverter. When...
502
Last night electricians replaced the panelview and now there is no comms between the panelview and the PLC. The processor is a 1747-L541 SLC 5/04...
899
I've been given a line that has several sysmac c200Hx PLCs. The First station Im trying to wrap my head around has a NS8 HMI. I'm using Cx-one...
747
Hi, I'm working on a project with an Allen-Bradley PLC, so we are using Studio5000. I have a bunch of things that communicate through ethernet/Ip...
1,248
Hi, Please I need your advice. 1. Master PLC Mitsubishi CPU-R04CPU + ETH module RJ71EN71 2. Master need to comm with AB CompactLogix 1769-L33ER &...
2,342
