IO not responding STEP 7
marvis
Mar 2016
Italy
108
I am newbie on Step7 and I had help in this forum for my project.
So, please, help me.
IO not responding but hardwarea configuration should be ok.
Where I am wrong?
Thanks in advance.
You have error lights on all your power modules. My first guess is that they are missing 24V.
Step 2, I guess, is to make sure that the part numbers for the PMs (including FW versions) match.
Edit: and you posted at the exact same time I did, hi5 for figuring it out!
You can configure the PM/E to give diagnostics if the 24v supply is missing. Unfortunately, the default setting is no diagnostics.
hello, I have a Maple Systems HMI5103L currently programed and running in conjunction with a AB 2080-LC50-24QWB. everything works fine data is...
721
Have tried to get the tag details from the PLC through python pycomm module.But getting Tag doesn't exist error. Am using pycomm version = 0.11.0...
509
Hi everyone. I worked with RedLion HMI several years, in the last year four CR3000 HMI (10 and 15") had have problems with the touchscreen. All...
1,266
some of the existing ethernet IO modules having problems after adding couple camera(Keyence IV3).Tried swapping the switch with a bigger one...
1,637
Hi every one am working on this machine ,where there is a motor that rotates an arm with high speed when the arm reaches the sensor the motor...
2,008
