Is it normal for 1788 ENB daughter cards to lose IP address on power loss?
Karinrinkashi
Nov 2017
Atlanta, GA
40
I am working with a 1788 ENB daughter ethernet card. It losses IP address every time i cut the power to the eletrical panel. I have to then BOOTP it and insert IP address over and over.
Is this normal when there is battery in the FlexLogix 5434 to which the card is attached, and yet the card keeps losing IP Address on power cycle?
Thank you in advance for your help!
No, it's not normal. All Logix-family network daughtercards, all the way back to the 1756-ENET, save their IP configuration object in onboard nonvolatile memory.
It is most likely that the Disabling of the BOOTP/DHCP option did not take effect.
Be sure that you have a Subnet Mask and Default Gateway that are compatible with the IP address you set; the module can't handle a Gateway and IP that aren't on the same Subnet and will default back to BOOTP/DHCP.
Not a PLC question but I need expert help on this. My FactoryTalk stopped communicating with the server its hosted on. I had an error stating...
146
Hi, I have a 1769-L32E,series A, compact logix controller which suddenly stopped working (as in all the outputs dropped out). The status of the...
1,281
For custom stuff at my last company we usually did 12 weeks. My current job is much more standardized and configured stuff, but we also handle...
1,373
Hello, I created in Tia portal an RPM in a normal input, taking care to use it in low rpm equipment. Using clockbits as a time reference. But on...
4,079
Hello everyone. I have a bunch of e300s connected to a startix which is then going to the plc. All of them are showing their MS and NS lights...
4,756
