Create a RPM on Micro820 with normal input
You can measure the time between each pulse. It takes 3 rungs of logic.
Rung 1. Use your input to one shot an OTE.
Rung 2. XIC of OTE Move Timer.ACC into a Storage DINT. Then Divide 60000 by Storage DINT and place in a Display DINT.
Rung 3. XIO of OTE Run Timer.
This will give you a Real Time RPM in your Display DINT.
edit: As long as your input is on for 2 scan cycles of the PLC then you will not miss any RPM values.
Derived from the problems and the little use of AB, I go the other way using analog signal directly from the frequency variator. It will be more work, due to the calculations of transmissions and ratios, but more reliable.
Because I need to have a ton/hour sampler. So it's just a matter of resorting to good math and applying it to automation.
Thanks for all the support, I will still come back to this approach in the future, because if it works on siemens, it also has to work on AB.
Thanks.
Hello, I've been trying to learn this a while now and still have not found out how this works. I have an Omron CJ2M PLC and an ABB ACS 355 VFD...
250
Hello, I have to deal with iFix again and am looking at the most efficient way to create alarms to display in iFix, i.e. not creating an...
157
Good morning to all, I have the following issue, I installed everything of intouch including the patch, it is the 2023 version. The...
336
So, I finally got versioin 27 installed on my Windows 10 VM. However, now I can't upload a project from my lab controller. I have the above error...
1,133
Hi all, I have few GB of logged data created by RS View 32 Works, it is all in .DBF format. At the moment, my company wants to shift all data to...
1,462
