let me explain it. I have successfully sent DO and DI, but I still don't know how I know that the CanOpen is run or there is a problem.
for example:
I enable can open from watch table by giving true value to can open manager control. But when there is a problem, the value in the watch table DO doesn't change to 0 (zero) but the value is still 1 (one). From here I want to find out how I know the status of can open is having problems through the program, so that when the can open is broken the DO value should also be broken and return to 0 (zero) value.
I hope for your help, thank you
for example:
