FT View SE V11 - PB->ME->SE Conversions Missing Images
Tanquen
Jul 2014
CA
163
Importing a number of SE, ME, PB, View32, WinView apps into View SE 11. Looking for a way to find and consolidate all the images into the one HMI Server and not overwrite each others. The conversions are not being done on the HMI Server and when they are imported the screens show an X where the bitmap should be.
You would need to convert them separately, and then manually merge them into one project, if your goal is to combine all the screens/tags/alarms into one project.
I remember with RSView32, that for some reason I had to convert it on Windows XP 32-bit (maybe Windows 7 32-bit *might* work, but 64-bit - no). I ended up using FT View V7 to convert from RSView32, then brought it into V10 or V11.
I was just trying to figure out the best way to find the images used and then consolidate. Some may be using an image with the same file name but it’s been customized or using a new image that has the happens to have the same as an image from another project.
Has anyone had luck using a checkbox control (specifically Microsoft Forms 2.0 Checkbox) on a graphic? I assigned a tag to the "Value" property...
1,507
Hello everyone, I'm getting some weird behavior from one of my displays in a FTView SE v11 application which has a total of 10 displays. The...
2,307
Can any one here help me convert my .mer file to target v10 or older? Please. Have a host of questions, but dont want to go off topic just yet...
1,990
Hello, I am having an issue accessing my 'online' tag data information from the PLC (1756-L81E) in the tag browser. The 'offline' tag folder is...
2,801
Hi, I've been using FactoryTalk Machine Edition V11 to create runtimes for countless HMI's at versions between 5.1 - 8.2 for several months now...
17
8,275
