yarn speed
irondesk40
Jan 2008
nc
630
Have a winding machine that was built in Italy that is basically a DC motor with a dancer arm that slows down the machine as yarn is wound onto a cone.
Has anyone used or had any experience with some type of sensor that might could be used that the yarn could be fed through to tell how fast the yarn is being pulled?
Thanks for any advice.
Must we assume that you would need a non-contact type of sensor? You can't for example wrap the yarn around a wheel attached to an encoder can you?
Or are you looking for something similar to an ammeter which go around the wire without touching it to measure the Current.
You can use an encoder in a sheave on the dancer arm to measure both footage and speed. The circumference of the spinning wheel varies slightly with the diameter of the yarn, but it should be more than accurate enough .
+1 on the Beta Laserspeed. It can communicate directly to most PLC's, and if that is impossible, or you are just using a counter, it can generate a quadrature output just like an encoder.
beta laserspeed looks interesting, but this is a very small diameter yarn type fiber material like you would see on a knitting machine. It is wound directly out of a extruder using a Leesona Fiber Winder that is basically a DC motor with a dancer arm and a take up roller that a cone is placed on then the fiber is wound on the cone and a guide oscillates back and forth to evenly roll the fiber onto the cone.
From your experience if the laserspeed detector was looking at the center of the cone that the fiber is would around, as the fiber wound around the cone and increased in diameter would the laserspeed detector be capable of displaying how many feet per minute the cone was turning?
Also, what is the cost for one of these units?
Does anyone know what the data transfer rate for this series of CompactLogix PLC's? 1769-L24ER-QB1B to be exact. Cheers.
131
Hello, I am trying to setup on plc so If I enter 60 jph (job per hour) it will send the vfd hertz based on what jph is entered by...
181
Sigh, DeviceNet noob... I have a 1756-L55, with a DeviceNet module, and 10 PF700 all commanded with DeviceNet. One of the PF700's blew up...
157
Do i have to use interrupt subroutine, or immediate read high speed input, for Unitronics Samba plc or reading only the correponding register in...
142
Hi all, I'm having trouble solving a problem I've been working on for several months, and thought you might like a stab at it. The machine runs...
22
1,035
