slc 5/04 cpu fault and not output card power
blamison
May 2009
PA
Our company has a machine that's running with a SLC 5/04 processor. Sometimes, in the middle of operation, the machine will stop, and the cpu fault light will be steady on, while the battery light blinks. Also, the input cards will still have power, but all the output cards go dead. Sometimes cycling power to the machine will reset whatever problem is occuring, and other times it won't.
We replaced the cpu with a spare, and the same thing happens. We also tried reseating cards, and powering up with the cpu disconnected, then with output cards disconnected. When this fault occurs, communication with the plc can not be established.
I thought there might be something wrong with the backplane, but I really am lost. Anyone have any ideas? Thanks.
quick guess is that you have a ground short on one of your outputs this may be pulling power from your output cards next time it happens try to remove the output wiring to isolate which one may be doing it
hello at work we have a machine controlled with an SLC 500 fixed, model 1747-l30c at fault, i plan to migrate to a micrologix controller. I'm...
3,015
Hello everyone, I got called down to a plant to service a powdered metal press. It has an SLC 500 5/02 CPU that was faulted for the code 0002h...
1,801
Hi, New guy here. We have older Allen Bradley SLC 150s in our six Automated mini-load supply units. One unit tripped a CPU fault, and will not...
5,137
Hi, I have a CPU Fault on my AB SLC500, although i can clear the fault, but when i do a test run, the fault came back. I'm not a PLC guy, and i...
2,035
I'm new to these boards and was wondering if someone can shed some light on my problem, Started up our Jensen cleaning machine and only half of it...
6,660
