Random Plant stoppage, I question DeviceNet network.
Rob S.
Sep 2008
Maryland
739
The last two days our automation has just stopped randomly at different spots. Everything that has stopped, is thru DeviceNet.We have about 5 faults on our HMI ( Panelview Plus )at the same time. Digging deeper into the faults, I took notice that they are faults dealing with a air cylinder ,reed switch, or motor not reaching a prox , etc. that has to reach that in a certain amount of time , or it will fault out.
I am thinking that the program is still running , but the DeviceNet Flex I/O is losing comunication for a split second.
I am not getting any DeviceNet faults. Do you think I am on the right track ? Have any of you had a DeviceNet network that has somewhat brokendown ,after being in service for a few years ?
Thanks in advance , have a great evening.
How are you detecting and trapping DeviceNet errors/faults ? What type of DeviceNet scanner are you using ?
DeviceNet uses a standard "4x RPI" timeout value. If you're using Polled I/O, and there are four Polls by the Master that are not responded to, the Master declares a timeout.
Similarly, if you are using Cyclic I/O connections, the Master declares a timeout after more than 4x the RPI has gone by without a reply from the slave.
After a Timeout has occurred, it takes between 1 and 4 seconds for a DeviceNet scanner and a FLEX adapter to re-start the connection. This is plenty of time for ladder logic to trap a fault bit, but too fast for most folks to check the scrolling display on the scanner.
It's certainly possible for a DeviceNet network to degrade over the course of a few years, just like any electronic system with field terminated wires. Corrosion, vibration, or increased noise on the system could start causing CAN network errors, and those could start causing I/O connection timeouts. Such problems absolutely will show up using a Woodhead NetMeter.
What's very unlikely is for the system to be able to have enough packet errors to miss I/O signals without also generating I/O Connection faults that can be trapped and diagnosed.
Is there anything else the I/O points have in common; a common DC supply or DC Common wire that might have loosened or failed ?
Be thankful the operators aren't describing this as a "PanelView fault" because the error messages are displayed on the PanelView.
I plan on purchasing a Woodhead NetMeter tomorrow. I read the manual a little before leaving the plant. I didn't see a discription of how to actually hook it up to the network. Is there any better discription on how to hook it up?
It seems like a difficult problem to solve ,being so random.
Thanks for your help,
The NetMeter comes with some tap cables that are meant for plugging into Mini and Micro quick-disconnects.
I frequently installed short drop cables for analyzer access, and made up my own cable with an open-style Combicon female socket. This would allow me to plug in either the NetMeter or my 1784-PCD for protocol analysis.
The NetMeter frequently does its job by showing no errors ! If I'm investigating a DeviceNet and it goes through a device failure but there are no CAN errors on the bus, I know that the device itself should be investigated, rather than the network.
Looking for some advice for backing up the programs on a bunch of old random PLCs. All I'm really concerned about is getting the program out of...
43
4,709
We have several Powerflex 4M (22F-D013N114) VFD’s controlled by compactlogix PLC’s. Control is simple, a run and direction signal with the speed...
1,524
Hi all, I know this is a PLC forum, but I know there is a gread deal of knowlege on drives as well. This drive has been running on stone...
886
Hey folks, I was just wondering what thoughts were about a completely 100% random number generator. I looked on The Google but didn't really open...
54
16,533
Hello Friends I need to activate random outputs (0-9) and ask for random inputs (0-9). I have created in s71200 a program to generate a random...
4,697
