EtherNet/IP - Modbus Mapping Configuration (GC-XPORT-EIP-MB)
puisan77
Nov 2006
Yokohama, Japan
Dear all,
Anyone please advise me on the Configuration of
EtherNet/IP to Modbus Mapping.
Attached Config.bin file which I have made, and
after uploading this file to the device
(GC-XPORT-EIP-MB) and rebooting, it doesn't reply
to PING, nor could the old configuration file
be uploaded to it. This is my first time doing
this kinda project and has little understanding
about MODBUS.
Please advise.
Attached manual from GridConnect and ConfigFiles.zip
Under ConfigFiles.zip, Config-xxx.bin is the file
that caused the device to stop responding after it
has been uploaded to the device, and
config.bin is the one, which works fine, till now (but
without any Modbus Mapping)
With Best Regards
Puisan
Modbus to EtherNet/IP
Hello mate,
did you find a solution for this. I am currently trying to map the modbus to EtherNet/IP and I am quite interested How you have 7d and your first byte start address, because what I thought was modbus addresses ranger from 1-254, so if your addressing should be 00 for first byte and then 7d for the other byte..Is this correct ?
A reply is much appreciated,
Regards,
Mihiri
Does anyone have any recommendations for Electronic Circuit Breakers with 0V Terminals built-in and Fieldbus (IO-LINK, MODBUS TCP, EtherNet/IP?)...
212
What's the cheapest way to go from modbus rtu rs485 to Ethernet IP or TCP. I've got some power transducers I'd like to read some modbus addresses...
1,407
Hello, Sorry, my knowledge of communication protocol is limited, so thank you in advance for your answer. My question; I want to get 5 values...
878
Hi All, Trying to help a client who has a project that was started with Schneider STB remote I/O, but they are still waiting on the STBNIP2212...
1,956
Hello all, I was wondering if you clever people could help me, please. In the past I have used a standalone L33ER CompactLogix PLC with the...
1,574
