A Free HMI with Eye Catching Graphics is Now Available
I don't want to use the Community Edition because the installation is huge.
I had to download Visual Studio build tools 2013 in order to open the solution in SharpDevelop.
Then in AdvancedHMIcs I referenced the MfgControl.AdvancedHMI.Drivers.dll and MfgControl.AdvancedHMI.Controls.dll in order for the advanced hmi controls and drivers to appear in the "Custom Components" tab in Tools.
The problems that when I drag and drop a driver from the toolbox I get an exception like in the attached image.
Visual Studio 2017 has addressed the issue with a massive install that took a long time by allowing you to select only the necessary components. For AdvancedHMI, you only need the Desktop Application workload.
Archie,
I don't know if it's a bug or if I'm doing something wrong but when I read a value using Modbus and show it on a basicLabel control and in order to show it with one decimal point you would normally set the scale to 0.1 .
I need to use comma (dot isn't allowed to be entered) to set the scale but it doesn't work.
So I need to change the region in Windows settings to English (US) so it can accept the dot in scale field.
Have a GE IC200CPU002 running a alarm monitoring program All of them are inputs except for the alarm sounder Looking for a free HMI which would...
826
The C-More remote HMI app on APP Store, Google Play and Amazon is now available free. The nominal charge has now been removed...
2,386
Hi I have a phoenix contact installation and I'm looking for hmi software to manage my project better. It has to be as cheap as possible, free if...
2,494
My brother recently bought a KEP HMI for a small project, he asked me to check out the software which is called EasyBuilder 8000...
3,732
Hello, i have a data historian system it is a GE proficy historian. i need an application that can be used to display the data in a HMI format. i...
25
9,589
