CLX MSGs to Honeywell via Ethernet
mort81
May 2014
Ohio
89
I have a customer that would like to read and write data from their Honeywell WEB-600E-O and WEB-8000 controllers to their utility PLC which is an L72 CLX. Does anyone know if it is possible to set up reads and writes from the CLX to the Honeywells? If so, any clues to the config for the MSG? For the sake of this argument, assume the same subnet (however reality will be multiple). I have calls into Honeywell, but those whom thought they could know are out on jobs and have not returned my call. So I wanted to ask the experts here, as I have not dealt with these Honeywells before. Any information is appreciated. Thanks in adavance!!
Thanks. I did request more info from them. But based on the limited information on the site, seems to be more for a SCADA driver than a peer to peer messaging for the CLX PLC? Am I missing something?
Controller: 1756-L84E v.35 Prosoft MVI56E-MNETC for ModbusTCP/IP I'm having an issue with some of my write commands. The write command that...
217
I have several Avery scale units and they are configured as Generic Ethernet modules, and I am actually reading the data fine for the weight...
455
What's the best way to move a tag value from the panelview+7 to the clx plc. We display amps from a power meter on the panelview screen, read in...
411
I'm running into an issue migrating a PLC-5 using the newer Logix Designer Export when opening a saved .ACD from RSLogix-5. It has multiple RIO...
640
We have two sites that are stranded with no line of site, they are handled by phone/modem with a chain that includes: Stranded site (client)...
932
