Translating MicroLogix 1500 ( RS Logix 500 ) to CompactLogix 1769-L18 (RS Logix 5000)
Rob S.
Sep 2008
Maryland
739
Good Morning ,
I have a MicroLogix 1500 program I would like to convert to a CompactLogix
1769-L18ER. Can I use the RS Logix 5000 Tools/ Translate PLC-5 SLC ? If so , I
took notice the 1769-L18ER was not listed in the controller types.
Thanks so much in advance.
The translation tool does a reasonable job, but does tend to make the resulting code hard to read, as it converts N7:35 type addresses to N7_35 tagnames.
If the program isn't too large, I would recommend just recoding it into the CompactLogix, making meaningfull tagnames as you go. How many rungs in total are there ??
There are opportunities to make the program better, more easily understandable, and it will be easier to spot areas of concern... the different rounding algorithm, for instance.
It is fairly large. I agree with you. It can be a simpler program if I rewrite it. How come more processors are not listed in Step 2 of the translate tool ?
Hi, I have a program that is mainly coded with Italian comments. I want to find a way to export all the comments and then run them through google...
1,339
I need to translate comments and symbol list in a Step7 project from italian to English. I know both languages but it seems very time consuming...
3,403
I have a s:7 status problem which is, as I could found related to the 0-7 racks of the plc (PLC 5) . However I tried to search in the GSV block...
2,996
Hi, I have a PCE instruccion error (PCE 103), due to the status file S[8] in plc5 when tralslating it to rslogix5000 . So my question is, how do I...
2,279
I have a siemens PLC 300 series. all of the programe from block names to the code, SCL is in german is there a way to translate this to english?:furi:
2,149
