I may not be able to help you As I have never used Schneider, you definitely need to be more specific you talk about vis & android, if you post what hardware you have, for example are you talking about an M241 talking to an android tablet what software is on the tablet for the visualisation, if so are you wanting to use the PLC RTC to display the time on the android ? if you post more detail perhaps someone here will be able to help you, I do know that the M241 has an RTC but the time I believe is stored in Dwords so is number of msec since 1970, I'm sure there will be functions to change it from this to a yyy/mm/dd, hh,mm,ss but why if using an android tablet use the plc clock it's never very accurate.
